Ir para o conteúdo principal
Hoover LiNX Replace The Motor Replacement
O que você precisa
  1. Hoover LiNX  Replace The Motor Replacement, Replace The Motor: passo 1, imagem 1 %32
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX  Replace The Motor Replacement: passo 2, imagem 1 %32
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX  Replace The Motor Replacement: passo 3, imagem 1 %32 Hoover LiNX  Replace The Motor Replacement: passo 3, imagem 2 %32
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX  Replace The Motor Replacement: passo 4, imagem 1 %32
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX  Replace The Motor Replacement: passo 5, imagem 1 %32
    • Remove the bottom panel.
  6. Hoover LiNX  Replace The Motor Replacement: passo 6, imagem 1 %32
    • Remove the motor.
Conclusão
3 outras pessoas executaram este guia.
Sara Vlhova
Membro desde: 01/25/18
541 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro de USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Membros
Autoria de 12 guias
3 comentários
Where does one get a new brush motor?
Brian - Responder
Thank you for the photos! They’ve been helpful as I’m putting my Linx back together and can’t quite remember how the wires go back in the nozzle assembly. When putting the top plate back on, it’s a very tight fit where the top will be pushed up if maligned.
In the elbow part- It looks like the positive lead is on the left in your photo, but it would be helpful if you would add that specification to your step.
Great Job!
Paulie Jeanne - Responder
In my case the (low quality) wires were broken and I had to just replace the wires from the motor to the contact points in the neck.
Paul Vale - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 36
Ao todo: 3,897
