Ir para o conteúdo principal
Honeywell HY-204 Rotation Motor Replacement
O que você precisa
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: passo 1, imagem 1 %32
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: passo 2, imagem 1 %32
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: passo 3, imagem 1 %32 Honeywell HY-204 Rotation Motor Replacement: passo 3, imagem 2 %32
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: passo 4, imagem 1 %32
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: passo 5, imagem 1 %32
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Conclusão
Equipe
Cal Poly, Team 10-40, Amido Fall 2014 Membro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
Membros da 3
Autoria de 7 guias
2 comentários
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 2,683
