Ir para o conteúdo principal
Honeywell HY-204 Fan Motor Replacement
O que você precisa
  1. Honeywell HY-204 Fan Motor Replacement, Case: passo 1, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement, Case: passo 1, imagem 2 %32
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: passo 2, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement: passo 2, imagem 2 %32
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: passo 3, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement, Fan Blades: passo 3, imagem 2 %32
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: passo 4, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement: passo 4, imagem 2 %32
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: passo 5, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement, Fan Motor: passo 5, imagem 2 %32
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: passo 6, imagem 1 %32 Honeywell HY-204 Fan Motor Replacement: passo 6, imagem 2 %32
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
Conclusão
Equipe
Cal Poly, Team 10-40, Amido Fall 2014 Membro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
Membros da 3
Autoria de 7 guias
2 comentários
Where do you purchase the replacement fan motors from?
mattb - Responder
Do you know where I can find the fan motor replacement?
Dave Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 6,477
