Introdução
After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
O que você precisa
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Quase terminado!
Conclusão
