Ir para o conteúdo principal
Honeywell HY-204 Control Panel Replacement
O que você precisa
  1. Honeywell HY-204 Control Panel Replacement, Case: passo 1, imagem 1 %32 Honeywell HY-204 Control Panel Replacement, Case: passo 1, imagem 2 %32
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: passo 2, imagem 1 %32 Honeywell HY-204 Control Panel Replacement: passo 2, imagem 2 %32
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: passo 3, imagem 1 %32 Honeywell HY-204 Control Panel Replacement, Control Panel: passo 3, imagem 2 %32
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: passo 4, imagem 1 %32
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Conclusão
Nolan Ernotte
Membro desde: 10/14/14
384 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-40, Amido Fall 2014 Membro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 540
