Ir para o conteúdo principal
Honeywell HT900C Motor Replacement
O que você precisa
  1. Honeywell HT900C Motor Replacement, Motor: passo 1, imagem 1 %32 Honeywell HT900C Motor Replacement, Motor: passo 1, imagem 2 %32 Honeywell HT900C Motor Replacement, Motor: passo 1, imagem 3 %32
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: passo 2, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 2, imagem 2 %32 Honeywell HT900C Motor Replacement: passo 2, imagem 3 %32
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: passo 3, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 3, imagem 2 %32
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: passo 4, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 4, imagem 2 %32 Honeywell HT900C Motor Replacement: passo 4, imagem 3 %32
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: passo 5, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 5, imagem 2 %32 Honeywell HT900C Motor Replacement: passo 5, imagem 3 %32
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: passo 6, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 6, imagem 2 %32
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: passo 7, imagem 1 %32
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: passo 8, imagem 1 %32 Honeywell HT900C Motor Replacement: passo 8, imagem 2 %32
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: passo 9, imagem 1 %32
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
Conclusão
Uma outra pessoa concluiu este guia.
Duy Anh Nguyen
Membro desde: 09/17/22
169 Reputação
Autoria de 1 guia
Equipe
York University, Team B-10, Allen Fall 2022 Membro de York University, Team B-10, Allen Fall 2022
YORK-ALLEN-F22SBG10
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 936
