Introdução
Honda Civic 2016 uses Keyless Remote to start the engine in addition to a normal lock/ unlock mechanism. Without battery, the car cannot be started. This guide show how to replace the Lithium battery inside Honda Civic 2016 Keyless Remote.
O que você precisa
Make sure to have replacement battery ready. You will need 1 pc of CR 2032 Lithium battery.
Remove the metal key by sliding the switch on the back of the remote and pulling the key out.
After removing the key, you will see 2 plastic bars. This is a place where you can split the remote open.
The manufacturer recommeded using a coin but any hard tool or even the key itself will work as well.
The manufacturer recommended using a cloth covering your coin/ tool to prevent it from denting the plastic bars.
Now you can gently pry it open
Removing the old battery from the left side.
Remember that the + side of the battery is facing up.
Inserting a new CR 2032 battery from the right side first and then press the battery down. It should make a good 'click' sound
Again, make sure the + side of the battery is facing upward.
13 outras pessoas executaram este guia.
