Ir para o conteúdo principal
Honda Fit Reset Oil Life Indicator Replacement
O que você precisa
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
Conclusão
You did it!
19 outras pessoas executaram este guia.
Jasen Friedle
Membro desde: 08/25/14
3.821 Reputação
Autoria de 3 guias
5 comentários
Great. I did it—and I’m a girl!!
pthompso99 - Responder
Excellent! Glad to hear it.
Jasen Friedle - Responder
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Responder
And how can I start the car that it won't start
sbukataake - Responder
Have you tried changing your blinker fluid?
neegnorg -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 125
Últimos 30 dias: 506
Duração total: 75,402
