Introdução
In order to access the brush assembly, the front cover of the alternator will need to removed first. The brushes play an important in role in transferring voltage from the rotor to the rest of the alternator.
O que você precisa
You should now be able to see the recifier assembly, the brushes are located in the middle of the recifier assembly.
Remove the brush assembly by unscrewing 2, 6mm center screws using a #2 Phillips head screw driver
