Ir para o conteúdo principal
Honda CSC29 Alternator Cover Removal
O que você precisa
  1. Honda CSC29 Alternator Cover Removal, Alternator Front Cover: passo 1, imagem 1 %32 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: passo 1, imagem 2 %32 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: passo 1, imagem 3 %32
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Alternator Cover Removal: passo 2, imagem 1 %32 Honda CSC29 Alternator Cover Removal: passo 2, imagem 2 %32 Honda CSC29 Alternator Cover Removal: passo 2, imagem 3 %32
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
Conclusão
8 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 25-1, Maness Spring 2016 Membro de Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 1,843
