Ir para o conteúdo principal
Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement
O que você precisa
  1. Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Disconnect the spark plug: passo 1, imagem 1 %32 Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Disconnect the spark plug: passo 1, imagem 2 %32
    • Before you begin, disconnect the spark plug connector from the spark plug.
  2. Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter assembly: passo 2, imagem 1 %32 Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter assembly: passo 2, imagem 2 %32 Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter assembly: passo 2, imagem 3 %32
    • Use a 10 mm socket to remove the three 12 mm-long bolts securing the recoil starter assembly.
    • Remove the recoil starter assembly.
  3. Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter pulley: passo 3, imagem 1 %32 Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter pulley: passo 3, imagem 2 %32 Honda 3000 Watt Generator EB3000CK2A Recoil Starter Assembly Replacement, Remove the recoil starter pulley: passo 3, imagem 3 %32
    • Use a 10 mm socket to remove the two 20 mm-long bolts securing the recoil starter pulley.
    • Remove the recoil starter pulley.
Conclusão
Uma outra pessoa concluiu este guia.
Tarun Thiruma
Membro desde: 11/20/19
35.352 Reputação
Autoria de 134 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 944
