Ir para o conteúdo principal
Homelite UT44172 Safety Switch Replacement
O que você precisa
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: passo 1, imagem 1 %32
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: passo 2, imagem 1 %32
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, imagem 1 %32 Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, imagem 2 %32 Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, imagem 3 %32
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: passo 4, imagem 1 %32
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Conclusão
Daniel Endericavillacis
Membro desde: 01/25/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 17-5, Watkins Winter 2015 Membro de USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 376
