Ir para o conteúdo principal
Homelite UT44172 Plastic Casing Replacement
O que você precisa
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: passo 1, imagem 1 %32
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: passo 2, imagem 1 %32 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: passo 2, imagem 2 %32
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Conclusão
Adam soto
Membro desde: 01/30/15
301 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-5, Watkins Winter 2015 Membro de USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 251
