Ir para o conteúdo principal
Homedics UHE-CMP15 Wick Replacement
  1. Homedics UHE-CMP15 Wick Replacement, Wick: passo 1, imagem 1 %32
    • Unscrew the top half of the device from the container and place the lid upside down.
    • The container should unscrew counter clockwise
  2. Homedics UHE-CMP15 Wick Replacement: passo 2, imagem 1 %32
    • Pull the wick holder out from the bottom of the lid.
    • Grasp onto the plastic wick holder and pull upwards until it pops free.
  3. Homedics UHE-CMP15 Wick Replacement: passo 3, imagem 1 %32
    • Remove the old wick from the wick holder.
    • Tilt the wick holder to the side and gently slide the wick out of its container.
  4. Homedics UHE-CMP15 Wick Replacement: passo 4, imagem 1 %32
    • Place new wick into the wick holder.
    • Grab a replacement wick from the box the humidifier came in and gently slide it into the wick holder.
  5. Homedics UHE-CMP15 Wick Replacement: passo 5, imagem 1 %32
    • Insert wick holder back into the lid.
    • Grab the wick holder and insert it into the lid on the end where the wick itself enters the lid and the spring side remains in the air.
Conclusão
To reassemble your device, screw the lid back onto the container and turn it on.
Dylan
Membro desde: 10/30/23
337 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 314
