Ir para o conteúdo principal
Homedics UHE-CMP15 Placement
  1. Homedics UHE-CMP15 Placement, Homedics UHE-CMP15 Placement: passo 1, imagem 1 %32 Homedics UHE-CMP15 Placement, Homedics UHE-CMP15 Placement: passo 1, imagem 2 %32
    • Move the device off of it's current surface.
  2. Homedics UHE-CMP15 Placement: passo 2, imagem 1 %32
    • Check the water tank for any damage that may have occurred during washing.
  3. Homedics UHE-CMP15 Placement: passo 3, imagem 1 %32
    • Take a look at the sensor to make sure there is no obstruction or blockage that may have occurred from the minerals in the water.
  4. Homedics UHE-CMP15 Placement: passo 4, imagem 1 %32
    • If there is, try using vinegar to decalcify the minerals in the water to clear out the blockage.
Conclusão
Dylan
Membro desde: 10/30/23
337 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 129
