Ir para o conteúdo principal
Homedics UHE-CMP15 Charging Cable Cleaning
O que você precisa
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: passo 1, imagem 1 %32 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: passo 1, imagem 2 %32
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: passo 2, imagem 1 %32 Homedics UHE-CMP15 Charging Cable Cleaning: passo 2, imagem 2 %32
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: passo 3, imagem 1 %32
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
Conclusão
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
Membro desde: 10/30/23
267 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 123
