Ir para o conteúdo principal
HomePod Mini speaker Replacement
O que você precisa
    • turn homepod mini upside down
    • peel back the foot cover
    • carefully cut the fabric mesh using the fabric scissors
    • be very careful not to scratch the delicate glass surface on top
    • unscrew the 4 torx screws on the bottom near the speaker holes
    • carefully seperate the top and middle sections from the homepod mini
    • be very careful when separating as there are cables connected to the motherboard as well as the speakers
    • carefully unplug all the cables connected to the motherboard
    • carefully separate the middle section of the homepod mini
    • carefully remove the speaker driver from the bottom part of the homepod mini
    • be very careful not to damage the delicate ribbon cable below the driver
    • remove the speaker driver
    • carefully remove the cables connecting to the driver being careful not to damage it
Conclusão
776831
Membro desde: 06/10/21
1.085 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 47
Duração total: 115
