Introdução
If the drone battery is malfunctioning, broken, or damaged, and needs to be replaced, since the battery is required to power the drone and enable all its functions. The only tool that is needed is a Phillips #0 screwdriver, and the replacement is quite easy and only requires a few minutes.
O que você precisa
Uma outra pessoa concluiu este guia.
