Ir para o conteúdo principal
Holystone HS 440 Controller Phone Stand Replacement
O que você precisa
  1. Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, imagem 1 %32 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, imagem 2 %32 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, imagem 3 %32
    • Start by removing the battery lid on the back of the controller.
    • Make sure to remove all the AAA batteries before removing the back panel.
    • After removing the lid, take your Phillips #0 screwdriver and remove the two 2mm Phillips #0 screws located right below where the batteries go.
  2. Holystone HS 440 Controller Phone Stand Replacement: passo 2, imagem 1 %32 Holystone HS 440 Controller Phone Stand Replacement: passo 2, imagem 2 %32 Holystone HS 440 Controller Phone Stand Replacement: passo 2, imagem 3 %32
    • Start prying the controller using the opening tool by sliding the tool through the breaks and applying some force to get it open. (it might require a bit of force)
    • After opening the controller, remove the four screws holding the phone stand and take the phone stand out.
Conclusão
Joaquin Botello
Membro desde: 02/08/24
85 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 21
Ao todo: 115
