Ir para o conteúdo principal
Holmes HEH8031 Safety Weight Replacement
O que você precisa
  1. Holmes HEH8031 Safety Weight Replacement, Housing: passo 1, imagem 1 %32
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: passo 2, imagem 1 %32
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: passo 3, imagem 1 %32 Holmes HEH8031 Safety Weight Replacement: passo 3, imagem 2 %32
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: passo 4, imagem 1 %32
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: passo 5, imagem 1 %32 Holmes HEH8031 Safety Weight Replacement, Safety Weight: passo 5, imagem 2 %32
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: passo 6, imagem 1 %32
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Conclusão
Deanna Jack
Membro desde: 10/12/16
333 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 2-1, Baechle Fall 2016 Membro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 553
