Ir para o conteúdo principal
Holmes HEH8031 Control Buttons Replacement
O que você precisa
  1. Holmes HEH8031 Control Buttons Replacement, Housing: passo 1, imagem 1 %32
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: passo 2, imagem 1 %32
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: passo 3, imagem 1 %32 Holmes HEH8031 Control Buttons Replacement: passo 3, imagem 2 %32
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: passo 4, imagem 1 %32
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, imagem 1 %32 Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, imagem 2 %32 Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, imagem 3 %32
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: passo 6, imagem 1 %32 Holmes HEH8031 Control Buttons Replacement: passo 6, imagem 2 %32 Holmes HEH8031 Control Buttons Replacement: passo 6, imagem 3 %32
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Shaffer
Membro desde: 10/12/16
255 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Baechle Fall 2016 Membro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 473
