Ir para o conteúdo principal
Holmes Blizzard Fan Oscillation Button Replacement
O que você precisa
  1. Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, imagem 2 %32 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: passo 1, imagem 3 %32
    • Using a Phillips #2 Screwdriver, remove the 3 screws located on the back of the fan cage.
    • Next, loosen the screw located on the bottom of the fan.
    • The bottom screw does not need to be removed, but only loosened about 3 or 4 turns.
    • The front of the fan's cage is now able to be removed by prying the front away from the back.
  2. Holmes Blizzard Fan Oscillation Button Replacement: passo 2, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 2, imagem 2 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 2, imagem 3 %32
    • Using a 7 mm socket and wrench, remove the 2 nuts that are behind the fan blades.
    • There is a washer located behind each nut. Be sure not to lose these.
  3. Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: passo 3, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: passo 3, imagem 2 %32
    • On the top of the fan, there is a screw fastening the oscillation button to the gear train within the housing. Remove this screw with the Phillips #0 Screwdriver.
  4. Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: passo 4, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: passo 4, imagem 2 %32
    • The on/off and fan speed nob can be removed by simply pulling it away from the main housing.
  5. Holmes Blizzard Fan Oscillation Button Replacement: passo 5, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 5, imagem 2 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 5, imagem 3 %32
    • Remove the 2 screws holding the clear plastic plate in place with a Phillips #2 Screwdriver.
    • The plate is now free and can be taken out by hand.
  6. Holmes Blizzard Fan Oscillation Button Replacement: passo 6, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 6, imagem 2 %32
    • The motor switch is also free and can be removed by hand to reveal a screw holding the housing assembly in place.
    • Be sure not to damage the wires on the switch during removal. While you do not need to be overly gentle during this step, excessive force could cause the wires to be pulled out.
  7. Holmes Blizzard Fan Oscillation Button Replacement: passo 7, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 7, imagem 2 %32
    • Remove the screw that holds the housing assembly in place by using a Phillips #2 Screwdriver.
  8. Holmes Blizzard Fan Oscillation Button Replacement: passo 8, imagem 1 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 8, imagem 2 %32 Holmes Blizzard Fan Oscillation Button Replacement: passo 8, imagem 3 %32
    • The housing assembly can now be pulled off and pushed to the side to reveal the fan motor and gear train.
    • The oscillation button the was unscrewed earlier will fall out of the housing assembly.
Conclusão
9 outras pessoas executaram este guia.
Mike Bolton
Membro desde: 07/17/16
570 Reputação
Autoria de 2 guias
4 comentários
I wanted to let you know how pleasantly surprised I was to find your post when looking for instructions on the oscillation feature of my fan that is just like this one. Thank you for posting.
nancysmyowner - Responder
Thank you for this info. This made it so easy for me to take my fan apart and clean it.
Pamela Dacus - Responder
I used this guide to fix a Holmes Air HAOF-7, which is virtually identical. It was seizing and clicking while oscillating. Oiling the gear assembly fixed it right up. Thanks for posting!
Soft Serve - Responder
Thank you for this information, really helped me out a lot
Zane C. Waldon Sr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 51
Últimos 30 dias: 308
Duração total: 19,727
