Ir para o conteúdo principal
Holley 4 Barrel Carburetor Gasket Replacement
O que você precisa
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: passo 1, imagem 1 %32 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: passo 1, imagem 2 %32 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: passo 1, imagem 3 %32
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: passo 2, imagem 1 %32
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: passo 3, imagem 1 %32
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: passo 4, imagem 1 %32
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: passo 5, imagem 1 %32
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: passo 6, imagem 1 %32 Holley 4 Barrel Carburetor Gasket Replacement: passo 6, imagem 2 %32
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: passo 7, imagem 1 %32
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: passo 8, imagem 1 %32
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: passo 9, imagem 1 %32 Holley 4 Barrel Carburetor Gasket Replacement: passo 9, imagem 2 %32
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 60
Duração total: 4,393
