Ir para o conteúdo principal
HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement
O que você precisa
  1. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: passo 1, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: passo 1, imagem 2 %32
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 2, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 2, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 3, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 3, imagem 2 %32
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 4, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 4, imagem 2 %32 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 4, imagem 3 %32
    • Disconnect the two cables with the red and white ends by pushing down the center tab at the end and pulling them out of their sockets.
  5. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: passo 5, imagem 1 %32
    • Remove the power supply board.
Conclusão
Johny
Membro desde: 09/08/23
557 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 102
