Ir para o conteúdo principal
HoMedics TotalComfort UHE-CM18 Oil Tray Replacement
  1. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement, Oil Tray: passo 1, imagem 1 %32
    • Lift up the water tank and separate it from the humidifier.
  2. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: passo 2, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: passo 2, imagem 2 %32 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: passo 2, imagem 3 %32
    • Use your finger to push in the oil tray to extend it out of its slot.
    • Pull the oil tray out.
  3. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: passo 3, imagem 1 %32 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: passo 3, imagem 2 %32
    • Remove the cotton oil pad before replacing the oil tray.
Conclusão
Johny
Membro desde: 09/08/23
557 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 68
