Introdução
If your humidifier is making loud noises or is not releasing mist, follow this guide to access the fan. This guide is an easy step-by-step process of how to remove your fan for a simple replacement. For this guide, you will need a Phillips #1 screwdriver head to remove and replace the fan.
O que você precisa
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Quase terminado!
Conclusão
