Ir para o conteúdo principal
Hitachi HB-B102 Automatic Home Bakery II Outer Casing Replacement
O que você precisa
  1. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement, Outer Casing: passo 1, imagem 2 %32
    • Make sure to unplug the device before starting.
    • Remove the lid by opening it to a 45 degree angle and pulling out.
  2. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 2, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 2, imagem 2 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 2, imagem 3 %32
    • Next, remove the two 1.3cm screws that hold on the control panel with a #2 Phillips head screwdriver. These screws, and the rest of the screws in this guide can all be removed using a #2 Phillips head screwdriver.
    • Then pull the control panel out of the device by using a metal spudger to pry it up. Flip it over and look at the back of the motherboard.
  3. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 3, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 3, imagem 2 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 3, imagem 3 %32
    • You will then have to disconnect the six wires that connect the motherboard to the device. This can be done by firmly grasping a connector and pulling straight out from the unit. Once all of the wires have been disconnected, set aside the control unit.
  4. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 4, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 4, imagem 2 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 4, imagem 3 %32
    • Remove the five 1cm screws that hold the the casing together. There will be two on each side, and one on the back.
  5. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 5, imagem 1 %32
    • Unscrew the four 1.4 cm screws surrounding the slot for the bread pan.
  6. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 6, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 6, imagem 2 %32
    • Now you can remove the top part of the assembly off by pulling straight up. Don't forget to gently pull your wires through.
  7. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 7, imagem 1 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 7, imagem 2 %32 Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 7, imagem 3 %32
    • Flip the machine over so that the bottom is facing straight up. Then unscrew the four feet on the device with a #2 Phillips head screwdriver. The screws will stay in the rubber feet.
    • Next, remove the four 8mm screws on the four sides of the machine. You do not need to unscrew the screws on the front end corners.
    • Once the feet and screws are undone gently pull the metal plate off.
  8. Hitachi HB-B102 Automatic Home Bakery  II Outer Casing Replacement: passo 8, imagem 1 %32
    • Now that the bottom plate and top housing are off, you can gently pull the inner components out of the outer metal housing . This can be done by grabbing hold of the bread pan casing and slowly lifting the entire inner assembly straight up.
    • You now have access to the belt and motor.
Conclusão
Mike
Membro desde: 01/25/17
397 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-2, Banghart Winter 2017 Membro de Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
Membros da 3
Autoria de 7 guias
Um comentário
hi! Thank you for this awesome demo. I have the BH 101, and the display doesn’t have screws. It has four little pad kind of things. Any idea how I might get those off?
Mary Vogel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 294
