Ir para o conteúdo principal
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
O que você precisa
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: passo 1, imagem 1 %32
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
    Pergunte ao FixBot
    Comentar
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: passo 2, imagem 1 %32
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
    Pergunte ao FixBot
    Comentar
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: passo 3, imagem 1 %32
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Mike
Membro desde: 01/25/17
397 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-2, Banghart Winter 2017 Membro de Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Membros
Autoria de 7 guias
1Comentário do guia
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 734
