Ir para o conteúdo principal
Hisense Sero 8 Charging Port Replacement
O que você precisa
  1. Hisense Sero 8 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Hisense Sero 8 Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Hisense Sero 8 Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
  2. Hisense Sero 8 Charging Port Replacement: passo 2, imagem 1 %32
    • Remove seven of the 4.43mm screws using the Philips #00 screwdriver.
    • It is not necessary to remove the bottom two 4.43mm screws that keep the speakers in place.
  3. Hisense Sero 8 Charging Port Replacement: passo 3, imagem 1 %32 Hisense Sero 8 Charging Port Replacement: passo 3, imagem 2 %32
    • Gently lift the motherboard up to extract the charging port out with the tweezers.
    • Be cautious not to disconnect any wires or ribbon cables.
Conclusão
Keanu
Membro desde: 02/23/15
367 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-2, Leahy Winter 2015 Membro de USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 7
Duração total: 3,786
