Ir para o conteúdo principal
Hisense Sero 7 Pro Battery Replacement
O que você precisa
  1. Hisense Sero 7 Pro Battery Replacement, Battery: passo 1, imagem 1 %32 Hisense Sero 7 Pro Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Battery Replacement: passo 2, imagem 1 %32 Hisense Sero 7 Pro Battery Replacement: passo 2, imagem 2 %32
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Battery Replacement: passo 3, imagem 1 %32 Hisense Sero 7 Pro Battery Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
Conclusão
Baochau Nguyen
Membro desde: 10/11/16
314 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 38-2, Bennett Fall 2016 Membro de Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
Membros da 4
Autoria de 6 guias
2 comentários
would be nice to actually have replacement battery avaible to buy new battery
howlingwolff10 - Responder
Where could one buy new battery?
Joshua Wood - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 19
Duração total: 2,671
