Ir para o conteúdo principal
Hipstreet Titan 2 HD Camera Replacement
O que você precisa
  1. Hipstreet Titan 2 HD Camera Replacement, Rear Case: passo 1, imagem 1 %32
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Camera Replacement: passo 2, imagem 1 %32
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Camera Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Camera Replacement: passo 4, imagem 1 %32 Hipstreet Titan 2 HD Camera Replacement: passo 4, imagem 2 %32
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Camera Replacement: passo 5, imagem 1 %32 Hipstreet Titan 2 HD Camera Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Camera Replacement: passo 6, imagem 1 %32
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Camera Replacement, Camera: passo 7, imagem 1 %32 Hipstreet Titan 2 HD Camera Replacement, Camera: passo 7, imagem 2 %32
    • Use your plastic opening tool to lift the black ribbon connector lock.
    • Then, proceed to remove the camera.
  8. Hipstreet Titan 2 HD Camera Replacement: passo 8, imagem 1 %32
    • Once the camera with the ribbon connector is removed, the process is complete.
Conclusão
Jeffrey
Membro desde: 03/11/15
766 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-6, Panko Spring 2015 Membro de Colorado Springs, Team 5-6, Panko Spring 2015
UCCS-PANKO-S15S5G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 387
