Ir para o conteúdo principal
Heyday Suitcase Turntable Motor Replacement
O que você precisa
  1. Heyday Suitcase Turntable Motor Replacement, Platter: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Unlock the front latches and open the turntable suitcase cover.
    • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
    • Be careful, as the spindle shaft may fly off in an unexpected direction.
    Pergunte ao FixBot
  2. Heyday Suitcase Turntable Motor Replacement: passo 2, imagem 1 %32
    • Use both hands to gently lift the platter up and off of the turntable.
    Pergunte ao FixBot
  3. Heyday Suitcase Turntable Motor Replacement, Baseboard: passo 3, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
    Pergunte ao FixBot
  4. Heyday Suitcase Turntable Motor Replacement: passo 4, imagem 1 %32
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
    Pergunte ao FixBot
  5. Heyday Suitcase Turntable Motor Replacement: passo 5, imagem 1 %32 Heyday Suitcase Turntable Motor Replacement: passo 5, imagem 2 %32
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
    Pergunte ao FixBot
  6. Heyday Suitcase Turntable Motor Replacement, Motor: passo 6, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
    • The motor is located underneath the platter.
    Pergunte ao FixBot
  7. Heyday Suitcase Turntable Motor Replacement: passo 7, imagem 1 %32
    • Flip the baseboard over.
    • Unplug the cable connecting the motor to the baseboard.
    • Remove the motor.
    Pergunte ao FixBot
Conclusão
Caroline D'Amato
Membro desde: 10/26/22
565 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Membro de UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 629
