Ir para o conteúdo principal
Heyday Round Bluetooth Speaker Subwoofer Replacement
O que você precisa
  1. Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker: passo 1, imagem 1 %32 Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker: passo 1, imagem 2 %32
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Subwoofer Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
  3. Heyday Round Bluetooth Speaker Subwoofer Replacement: passo 3, imagem 1 %32
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  4. Heyday Round Bluetooth Speaker Subwoofer Replacement: passo 4, imagem 1 %32
    • Once the hardware is opened by the screwdriver, both sides of the motherboard will be exposed and ready for any needed repairs.
  5. Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: passo 5, imagem 1 %32 Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use curved tip tweezers to detach the connectors of two 2-prong Aux In/Out plugs extending from the subwoofer.
  6. Heyday Round Bluetooth Speaker Subwoofer Replacement: passo 6, imagem 1 %32 Heyday Round Bluetooth Speaker Subwoofer Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four screws at the edge of each subwoofer to release them.
    • Remove both subwoofers.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 277
