Introdução
This guide demonstrates how to do a hand sewn herringbone stitch to repair a split seam on a Patagonia® fleece jacket. The herringbone stitch is ideal for reinforcing seams on stretch fabrics or creating flexible, decorative finishes with its crisscross design.
Hand sewn repairs are a fun and effective way to extend the life of gear at home. DIYs repair won't void the Patagonia warranty—they're actually encouraged!
Patagonia items can also be taken in to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
Related Articles
O que você precisa
Locate the damaged area and trim away any loose or hanging threads.
If necessary, pin the seam together so that it stays in place during stitching.
The herringbone stitch follows two parallel lines, with the thread creating a crisscross pattern between them.
Before beginning, determine:
Stitch Width - The distance between the two parallel stitch lines. Mark both lines with chalk or heat-erasable pen.
Diagonal Stitch Length - The length of the diagonal stitch moving from one stitch line to the other that creates the crosshatch pattern.
Backstitch Length - The length of the small backstitch that secures each diagonal stitch.
Thread the needle with a length of thread approximately 24 inches (~61 cm) and tie a knot at one end of the thread. For more details see Needles and Thread.
From the backside, insert the needle through to the front at a marked stitch line. Overlap any existing stitching by at least 1/2 inch (~13 mm).
Pull the thread through until the knot lies flush against the back of the fabric.
On the front side, move the needle diagonally across the seam in the direction of the stitch path.
Insert the needle into the opposing stitch line at the Diagonal Stitch Length determined in Step 3.
Make a small stitch backwards along the marked stitch line with the Backstitch Length determined in Step 3.
Pull the thread through.
Move diagonally across the seam again.
Insert the needle, make a backstitch, and pull the thread through.
Repeat the diagonal and backstitch sequence, forming a crisscross pattern along the seam.
Continue stitching until the repair extends at least 1/2 inch (~13 mm) beyond the damaged area.
To complete the stitch, move the needle to the backside and make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways).
Ensure the stitches have effectively secured the seam.
For additional strength and coverage, repeat these steps to add another stitch line.
Check the tension frequently while stitching, especially when repairing a slit or split seam, where fabric edges may shift.
Adjust as needed by gently pulling or loosening the thread to ensure the stitches lie flat without distorting the fabric.
Pause periodically to smooth the fabric and confirm the stitch tension is even along the repair.
