Introdução
If the high-low switch no longer works either the switch or PCB needs replacing.
If the motor powers up for a second when turns off and then dies it can also be a problem with the PCB.
The PCBs for Henrys can be expensive and hard to source but it can be easily bypassed. This will remove the high-low function but it will still work.
O que você precisa
Vídeo de Apresentação
Make sure it unplugged from the mains.
Pull out the black clips on each side of the head.
Remove the 4 outer Phillips screws
Remove the cable reel from the top
Pull the PCB out of its slot inside the housing
Remove all of the wires from the PCB
Remove the 2 wires from the on-off switch which connected to the rest of the vacuum cleaner.
Connect the 2 white wires from the motor to the green on-off switch.
Place the red high-low switch back in to its holder in the casing to fill the gap and prevent potential shocks.
Optionally, an indicator LED can be purchased online to fill the gap.
