Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Arquivado
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
Arquivado
Introdução
How to replace or upgrade your storage in a Hello Zee Smart Core.
  1. This particular model is 64GB This particular model is 64GB
    • This particular model is 64GB
  2. Insert the metal spudger into a corner and pry the 2 halves apart  be careful not to puncture the battery Insert the metal spudger into a corner and pry the 2 halves apart  be careful not to puncture the battery Insert the metal spudger into a corner and pry the 2 halves apart  be careful not to puncture the battery
    • Insert the metal spudger into a corner and pry the 2 halves apart be careful not to puncture the battery
  3. You can use the pointes end of the metal spudger to unscrew the 2 screws
    • You can use the pointes end of the metal spudger to unscrew the 2 screws
    • Replace the yellow plastic board cover when reassembling
  4. Pry the circuit board up Under the circuit board, there will be a MicroSD card slot Take out the MicroSD card
    • Pry the circuit board up
    • Under the circuit board, there will be a MicroSD card slot
    • Take out the MicroSD card
Conclusão
Uma outra pessoa concluiu este guia.
Levi G
Membro desde: 13/07/2018
2.678 Reputação
20 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 22
