Introdução
Are your heel tips worn down or missing? Walking on metal tips, or uneven worn down rubber tips can be extremely frustrating. With extensive wear, heel tips will naturally deteriorate. It is recommended that they are replaced before the inner tip begins to protrude. This is also important because having an unstable heel can lead to balancing issues.
If you or someone you know have worn down or missing heel tips, you can use this guide to learn how to simply replace your old heel tips with new tips. Why pay a shoe repair shop to replace heel tips, when you can do it yourself and save time and money.
O que você precisa
13 outras pessoas executaram este guia.
