Ir para o conteúdo principal
Health o Meter HDR743 Power Supply Replacement
O que você precisa
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: passo 1, imagem 1 %32
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: passo 2, imagem 1 %32
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: passo 3, imagem 1 %32
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: passo 4, imagem 1 %32 Health o Meter HDR743  Power Supply Replacement: passo 4, imagem 2 %32
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 130
