Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Headphone Jack
O que você precisa
  1. Headphone Jack, Battery: passo 1, imagem 1 %32
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: passo 2, imagem 1 %32
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: passo 3, imagem 1 %32 Headphone Jack: passo 3, imagem 2 %32
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: passo 4, imagem 1 %32
    • Pull battery out.
  5. Headphone Jack, Keyboard: passo 5, imagem 1 %32
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: passo 6, imagem 1 %32
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: passo 7, imagem 1 %32
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: passo 8, imagem 1 %32
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: passo 9, imagem 1 %32
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: passo 10, imagem 1 %32
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: passo 11, imagem 1 %32
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: passo 12, imagem 1 %32 Headphone Jack: passo 12, imagem 2 %32 Headphone Jack: passo 12, imagem 3 %32
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: passo 13, imagem 1 %32
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: passo 14, imagem 1 %32
    • Use plastic pry tool to lift up on headphone jack assembly
Conclusão
Tyler Lirio
Membro desde: 02/13/18
93 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membro de USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 193
