Ir para o conteúdo principal
Hayward SharkVac W3RC9740CUB Filter Panels Replacement
O que você precisa
  1. Hayward SharkVac W3RC9740CUB Filter Panels Replacement, Hayward SharkVac W3RC9740CUB Filter Panels: passo 1, imagem 1 %32
    • Unplug the robotic unit and set it on a flat surface.
    Pergunte ao FixBot
    Comentar
  2. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 2, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 2, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 2, imagem 3 %32
    • Gently turn the robotic unit onto its side with the unplugged power cord side facing up.
    • Hold on to the top of the robot to ensure it doesn't fall and break.
    • Keep your left hand on top of the unit for support while pushing the button in on the front.
    • While holding the button in, lift the cover up.
    Pergunte ao FixBot
    Comentar
  3. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 3, imagem 1 %32
    • Gently set the robotic unit back down on the flat surface.
    Pergunte ao FixBot
    Comentar
  4. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 4, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 4, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 4, imagem 3 %32
    • Lift the the filter bucket up to remove it from the unit, and set it on the ground.
    Pergunte ao FixBot
    Comentar
  5. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 5, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 5, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 5, imagem 3 %32
    • Using both hands, gently pull the filter door latches on the left out to the sides and lift the door upward.
    Pergunte ao FixBot
    Comentar
  6. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 6, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 6, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 6, imagem 3 %32
    • Using both hands, gently pull the filter door latches on the right out to the sides and lift the door upward.
    Pergunte ao FixBot
    Comentar
  7. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 7, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 7, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 7, imagem 3 %32
    • Gently wiggle the filter panel closest to you from side to side and pull it upward to remove it.
    Pergunte ao FixBot
    Comentar
  8. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 8, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 8, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 8, imagem 3 %32
    • Remove the second filter panel on the opposite side by gently wiggling it from side to side and pulling it upward.
    Pergunte ao FixBot
    Comentar
  9. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 9, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 9, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 9, imagem 3 %32
    • Insert the new filter panel furthest from you into the slot, making sure the black plastic is facing the center of the bucket.
    Pergunte ao FixBot
    Comentar
  10. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 10, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 10, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 10, imagem 3 %32
    • Insert the new filter panel into the slot closest to you, ensuring that the black plastic faces the center of the bucket.
    Pergunte ao FixBot
    Comentar
  11. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 11, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 11, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 11, imagem 3 %32
    • Bring the filter door latches down on both sides of the filter panels to lock them into place.
    Pergunte ao FixBot
    Comentar
  12. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 12, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 12, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 12, imagem 3 %32
    • Place the filter bucket back in the center of the robotic unit.
    Pergunte ao FixBot
    Comentar
  13. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 13, imagem 1 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 13, imagem 2 %32 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: passo 13, imagem 3 %32
    • Close the top of the unit, ensuring that the button in the front locks into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Now you have successfully changed the filter panels in your robotic vacuum pool cleaner. Happy swimming!
Uma outra pessoa concluiu este guia.
LauraS
Membro desde: 03/02/24
247 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 94
Ao todo: 611
