Ir para o conteúdo principal
Havoc Heli IR LED Replacement
O que você precisa
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, imagem 1 %32 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, imagem 2 %32
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: passo 2, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 2, imagem 2 %32 Havoc Heli IR LED  Replacement: passo 2, imagem 3 %32
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: passo 3, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 3, imagem 2 %32 Havoc Heli IR LED  Replacement: passo 3, imagem 3 %32
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: passo 4, imagem 1 %32
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: passo 5, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 5, imagem 2 %32
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: passo 6, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 6, imagem 2 %32
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Kent
Membro desde: 03/30/16
128 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 543
