1. Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
    • Use a #0 Phillips head screwdriver and unscrew the sixteen 7mm screws on the back of the device.
  2. Use a plastic opening tool to take off the back plastic panel. Use a plastic opening tool to take off the back plastic panel. Use a plastic opening tool to take off the back plastic panel.
    • Use a plastic opening tool to take off the back plastic panel.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable. To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable. To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
    • To take out the Graphics card fan it is necessary to disconnect the two Graphic card fan cables. Use a plastic opening tool to remove the cable.
  5. Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
    • Use a #0 Phillips head screwdriver and unscrew the five 7mm screws holding the fan in place.
  6. Lift the Graphics card fan out and replace with the replacement fan. Lift the Graphics card fan out and replace with the replacement fan.
    • Lift the Graphics card fan out and replace with the replacement fan.
Conclusão
Uma outra pessoa concluiu este guia.
Zachary Gay
124 reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G6, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S6G6
3 Membros
6 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Todo: 64
