Ir para o conteúdo principal
Hasbro Bop-It Micro Series Speaker Replacement
O que você precisa
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: passo 1, imagem 1 %32
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: passo 2, imagem 1 %32
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: passo 3, imagem 1 %32
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: passo 4, imagem 1 %32 Hasbro Bop-It Micro Series Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: passo 5, imagem 1 %32
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
Conclusão
Follow the steps of this guide in reverse to reassemble.
Glenn Haag
Membro desde: 09/29/16
479 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-1, Harley Fall 2016 Membro de IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,123
