Ir para o conteúdo principal
Hasbro Bop-It Micro Series Buttons Replacement
O que você precisa
  1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: passo 1, imagem 1 %32
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Buttons Replacement: passo 2, imagem 1 %32
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Buttons Replacement: passo 3, imagem 1 %32
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: passo 4, imagem 1 %32
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  5. Hasbro Bop-It Micro Series Buttons Replacement: passo 5, imagem 1 %32
    • After removing the buttons, solder new, operational buttons back into place.
Conclusão
3 outras pessoas executaram este guia.
Glenn Haag
Membro desde: 09/29/16
479 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-1, Harley Fall 2016 Membro de IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 1,897
