Introdução
If you need to access the insides of your speaker, you first have to take apart the device. This guide walks you through how to take apart the front panel.
O que você precisa
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
To reassemble, follow these steps in reverse order.
Um comentário
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
