Ir para o conteúdo principal
Harman Kardon Onyx Studio 2 Circuit Board Replacement
O que você precisa
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: passo 1, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: passo 1, imagem 2 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: passo 1, imagem 3 %32
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 2, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 2, imagem 2 %32
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 3, imagem 1 %32
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 4, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 4, imagem 2 %32
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: passo 5, imagem 1 %32
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 6, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 6, imagem 2 %32
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 7, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 7, imagem 2 %32
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: passo 8, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: passo 8, imagem 2 %32
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 9, imagem 1 %32 Harman Kardon Onyx Studio 2 Circuit Board Replacement: passo 9, imagem 2 %32
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
Conclusão
11 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 16-5, Blackwell Spring 2017 Membro de USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
Membros da 3
Autoria de 24 guias
5 comentários
Where do I get another one
Adrian tlahuel - Responder
Where we buy the board?
Eric Therrien - Responder
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - Responder
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - Responder
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 29
Últimos 30 dias: 144
Duração total: 21,867
