Introdução
Is the audio from your Invoke smart speaker distorted or scratchy? If so, one of the three speakers in your invoke might need to be replaced. All you need for this replacement is a Phillips #2 screw driver, a Torx #10 screw driver and a metal spudger tool.
O que você precisa
Use metal spudger to remove top cover from smart speaker.
Use the Phillips #2 screwdriver, remove the three 17mm screws.
