Ir para o conteúdo principal
Harman Kardon Invoke Speaker Replacement
O que você precisa
  1. Harman Kardon Invoke Speaker Replacement, Speakers: passo 1, imagem 1 %32 Harman Kardon Invoke Speaker Replacement, Speakers: passo 1, imagem 2 %32 Harman Kardon Invoke Speaker Replacement, Speakers: passo 1, imagem 3 %32
    • Use metal spudger to remove top cover from smart speaker.
    • Use the Phillips #2 screwdriver, remove the three 17mm screws.
  2. Harman Kardon Invoke Speaker Replacement: passo 2, imagem 1 %32 Harman Kardon Invoke Speaker Replacement: passo 2, imagem 2 %32 Harman Kardon Invoke Speaker Replacement: passo 2, imagem 3 %32
    • Once the 17 mm screws are removed, lift the volume wheel.
    • Lift slowly as you do not want to damage the cable connected to the LED board.
    • Pull lightly on the cable in order to remove both the volume wheel and LED board.
  3. Harman Kardon Invoke Speaker Replacement: passo 3, imagem 1 %32 Harman Kardon Invoke Speaker Replacement: passo 3, imagem 2 %32 Harman Kardon Invoke Speaker Replacement: passo 3, imagem 3 %32
    • Use the Torx #10 screwdriver, remove the four 14 mm screws around the lid.
    • Remove lid.
  4. Harman Kardon Invoke Speaker Replacement: passo 4, imagem 1 %32 Harman Kardon Invoke Speaker Replacement: passo 4, imagem 2 %32 Harman Kardon Invoke Speaker Replacement: passo 4, imagem 3 %32
    • Once lid is removed, housing can now slide upwards.
    • Use the Torx #10 screwdriver, remove both 10 mm screws for each speaker that must be replaced.
  5. Harman Kardon Invoke Speaker Replacement: passo 5, imagem 1 %32
    • Pull on the speaker cables lightly in order to detach the speakers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 1,248
