Introdução
If your Invoke is not connecting to your computer in order to be serviced, there might be a problem with the service port and should be replaced. For this replacement you will need a metal spudger and a #10 Torx screwdriver.
O que você precisa
Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports.
Pull board up lightly.
Uma outra pessoa concluiu este guia.
