Ir para o conteúdo principal
Harman Kardon Invoke Microphone on/off Button Replacement
O que você precisa
  1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: passo 1, imagem 1 %32 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: passo 1, imagem 2 %32
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: passo 2, imagem 1 %32 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: passo 2, imagem 2 %32
    • Use a Torx #10 screwdriver to remove the four 14.0 mm screws.
  3. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: passo 3, imagem 1 %32 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: passo 3, imagem 2 %32
    • Firmly grip the bottom and wiggle it upwards to remove the base.
  4. Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: passo 4, imagem 1 %32 Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: passo 4, imagem 2 %32
    • Use a Torx #10 screwdriver to remove three 10.0 mm screws from the highlighted board attached to microphone button.
  5. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: passo 5, imagem 1 %32 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: passo 5, imagem 2 %32
    • Pull the cable lightly to disconnect the button board from device.
    • To replace the microphone button, you will have to replace the entire smaller board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 583
